Inviato da Lappi il Mar, 01/27/2026 - 17:59
Anybody using GNUMail?
Am reading about different email clients. Is anybody here using GNUMail, or has used it in the past? If yes, what are your experiences, things to be aware of?
https://www.nongnu.org/gnustep-nonfsf/gnumail/index.html
Mar, 01/27/2026 - 19:38
#1
Evolution / Icedove are the most feature rich ones for simple use.
There are several other options some light, simpler, even via command line, but you are required to know more on each piece.
