Backup (Duplicity) not working
My computer was automatically backing up with Trisquel GNOME's default backup software, and this error appeared.
Could not restore ‘/home/joshua/.cache/deja-dup/metadata’: File not found in backup
I'm afraid the backup software isn't functioning properly; I accidentally messed up the location of some files and tried restoring the directory, but very few of the files were successfully restored, so I had to reorganize it manually.
Is there any way to run the program in a debug mode to see why it isn't working?
if you run it from a terminal it might give you some usefull output
