BUG: Work Space Switcher Can't Rename Work Spaces
In the workspace switcher properties you are suppose to be able to rename the workspaces and you can't, also everything that comes after the 3rd workspace that you add gets named 'Workspace' and you can't remove that name and just leave it as a number;
Here's a screen shot;
http://postimage.org/image/2qy2b2dr8/
Also in the title of the window the word Preference is cut off... :(
Sorry forgot to mention this is in 4.5 x86_64...
THANKS
I'm able to. Try highlighting a workspace name, then click it with
the left mouse button or press enter key to start renaming it.
ok my bad I didn't realize or forgot about hitting Enter, hehe...
THANKS
