Cannot mount external harddrive
Hello Trisquel community,
I am new to Linux. Here are the details.
Computer: Macbook Pro 2013 15" 1TB
Desktop Environment: MATE
1. Connected external HD with pre-Trisquel data using Thunderbolt 2 port. HD lights turn on. No response.
2. Second attempt. Connected HD with USB 3.0 cable to previously functioning USB port. Lights turn on, HD fans turn on. Error message on computer display.
3. Device is shown in MATE file explorer. Once clicked, same error message.
Error message: "error mounting /dev/sdc2 at /media/" + "wrong fs type, bad option, bad superblock on /dev/sdc2, missing codepage or helper program, or other error"
* /media/(user account)/(device name)
How can I connect to this external HD?
*2. What I had perceived to be fan noise was HD disk spinning.
Can you read the data on that partition from another system? Copy them somewhere so that you would not lose anything formatting? Formatting can be done from Trisquel. Even from from Trisquel' live system, using GParted.
That error sometimes means that you don't have the necessary file system support installed. If that drive was used with MacOS, it probably has HFS+ or APFS, which I don't think Trisquel has installed out-of-the-box. You can try lsblk -f to find out the file system type. If it's HFS+, you will need to install hfsprogs and/or hfsplus. If it's APFS, you can try apfsprogs.
If this isn't enough information, please post the output of `lsblk -f`.
Dear bernie and Magic Banana,
Using the Disk application in MATE, I realized the partition was inaccessible. Thankfully, I have access to another Apple computer. Using Disk Utility app in MacOS, I am attempting to create a large enough partition to transfer files, then increase partition size, repeat process, until all visible folders are in the MS DOS (FAT) partition.
Initially, I created a partition as large as all the available space on hard drive, which resulted in hours long wait to receive error on MacOS after ‘shrinking file system’ step on menu. MacOS suggested to pick smaller partition size, which I did and have been waiting past hour or two for process to complete.
If my other hard drive had enough space, I would transfer it over. I’d like to avoid buying another. I’ll update you on the results of this method.
Dear bernie and Alice Wilton,
Thank you for redirecting my attention. Before sinking further into the long aforementioned process, I installed the packages you both mentioned. After I installed them, I restarted the computer and tried to mount the HD from Disks application on MATE, and received a similar error.
Error mounting /dev/sdb2 at /media/USER/G-DRIVE Mobile: wrong fs type, bad option, bad superblock on /dev/sdb2, missing codepage or helper program, or other error (udisks-error-quark, 0)
I also ran the command bernie suggested. Here is the output:
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
sda
├─sda1
├─sda2
│ vfat FAT32 73B2-5E39 511.7M 0% /boot/efi
├─sda3
│ ext4 1.0 3965f1b8-d946-4d31-9007-9b9d91cb5141 1.3G 10% /boot
└─sda4
crypto 2 422c1931-4d74-4afa-918b-c9480d1005f1
└─sda4_crypt
LVM2_m LVM2 cvzWvY-3UQ6-aDvh-bUvT-U01h-fpaT-tnIG7O
├─vgtrisquel-root
│ ext4 1.0 ca670e00-7936-480e-b6f1-69ac7931b91b 12.1G 42% /
├─vgtrisquel-swap_1
│ swap 1 6f515ed2-cbf5-4a9f-adb8-cfe1956f362f [SWAP]
└─vgtrisquel-home
ext4 1.0 2ea34a50-c5b2-4cde-8817-0d36ceebbf1d 839.7G 0% /home
sdb
├─sdb1
│ vfat FAT32 EFI 67E3-17ED
├─sdb2
│ hfsplu G-DRIVE Mobile
│ 600ca59d-5811-3ffa-8ac9-75be855ceda3
├─sdb3
│ hfsplu Boot OS X
│ 590b1ac6-84f6-31dc-a9d6-6afc8f5cb0d2
└─sdb4
vfat FAT32 LINUX 803D-1C1A 97.2G 48% /media/USER/LINUX
sdc
Dear Alice Wilton,
I transferred back the data I moved and deleted the partition in hope to preserve data. I ran the second read-write mode code first. Received this error:
sudo mount -t hfsplus /dev/sdc2 /mnt
mount: /mnt: wrong fs type, bad option, bad superblock on /dev/sdc2, missing codepage or helper program, or other error.
Then I reran bernie's command:
sda
├─sda1
├─sda2
├─sda3
└─sda4
└─sda4_crypt
├─vgtrisquel-root
├─vgtrisquel-swap_1
└─vgtrisquel-home
sdb
sdc
├─sdc1
├─sdc2
└─sdc3
hfsplu Boot OS X
Then, I tried the first line of code you suggested, and received the error again.
Dear Alice Wilton,
I haven't been successful. The first method produced this error:
sudo mount /dev/sdc2 -t hfsplus -o ro,sizelimit=134217728
mount: /dev/sdc2: can't find in /etc/fstab.
For the second method, the first step, MacOS Internet Recovery mode terminal command diskutil cs list results showed under the groups > Physical Volume
Index: 0
Disk: disk4s2
Status: Online
Size: long numbers (999.9 GB)
> Logical Volume
Encryption Type: None
> Logical Volume:
Disk: disk5
Status: Online
Size (Total): long numbers B(999.5GB)
Revertible: Yes (no decryption required)
...names...
Content: Apple_HFS
However, when I ran the second step command I received this error:
diskutil cs revert /dev/ disk5
diskutil: did not recognize coreStorage verb "revert"; type "diskutil coreStorage" for a list
Upon further searches, I read Apple removed this function from updated software. If I run into an older version, then I will try it again.
Thank you for taking the time to help me. Do you think there is an alternative or should I continue with the partitioning and re-partitioning with another format? The options are AFPS, Mac OS Extended and MS-DOS (FAT).
Dear Alice Wilton,
The physical volume is described as Time Machine and Files. I believe this is the cause of the difficulty, but I am not sure what to do about it. I think I do not have the Time Machine backup password.
I've edited the post above please see.
Did you try adding `/mnt` to the mount command as Alice Wilton suggested? You may be that close to getting this to work.
The error that you showed: mount: /dev/sdc2: can't find in /etc/fstab. just means that `mount` doesn't know where to mount the partition. If you don't specify a location, mount will look in the /etc/fstab file to see if it's defined there. But you don't need to mess with /etc/fstab, the simplest thing is to add ` /mnt` to the end of the mount command, and let us know if you still get an error.
I'm not familiar with diskutil from macOS, but
and
suggests that encryption and a lost password are not the issue here.
Dear bernie,
I attempted Alice Wilton's step again, however I received a similar error:
sudo mount /dev/sdc2 -t hfsplus -o ro,sizelimit=134217728 /mnt/
[sudo] password for USER:
mount: /mnt: wrong fs type, bad option, bad superblock on /dev/loop0, missing codepage or helper program, or other error.
I was able to borrow another harddrive and Mac from someone. My plan is to temporarily transfer files on the MacOS computer, partition the majority of my HD to APFS linux accessible partition, since I cannot resize as I had expected. Yet, the borrowed HD is APFS and it did not mount on Trisquel Macbook Pro. ....: unknown filesystem type 'apfs'. I will troubleshoot it with same steps as before and will search online for more help.
I will update you on the results.
I observed before installing Trisquel, my USB keyboard or mouse wouldn't work in random orders. Sometimes the mouse, sometimes the keyboard. Mostly the keyboard near the power source. It often resolved itself if I restarted the computer and unplugged the power source at start up. I felt as if these were "monkey fixes", illusory solutions to complex problems. I tried booting without power cable again to see if it helped the computer cooperate with the USB port, and I did notice the /dev/ port name changed.
Hi cosmicadventure,
Something strange going on here, none of your other comments have mentioned a `/dev/loop0`. There shouldn't be a loop device in play here. Can you check that your external drive is still /dev/sdc2? (it may have changed if you've removed it and plugged it in again).
APFS will require different drivers, have you installed `apfsprogs`?
sudo apt install apfsprogs
Another way would be to connect the MacOS computer and your MacBook running Trisquel to the same local network, and have the MacOS computer share the HDD via the network (with the SMB protocol, that is well supported by Windows, GNU/Linux, other OSs) so you can make a copy of all the data to your MacBook running Trisquel via the network.
That way, no need for any kind of partioning.
It should be easy to access the shared HDD from Trisquel, via the file manager (caja).
Hi cosmicadventure,
Not sure if the solution in this video could be of help, just in case, I'm adding a link for you to check. Although this is a solution for a non-booting machine, it seems to offer options that could do the trick, I hope.
https://www.youtube.com/watch?v=kDs8XXW_oGo
"In this video I'll show you how to use Ubuntu 20.04 and libfsapfs-utils to extract files from a non-booting Mac. You won't need to take apart the computer or make any permanent changes to the hardware and all of the software tools used are free."
And how about booting from Trisquel instead of Ubuntu :)
Thank you all for the great info - I'll bookmark this thread for reference!
Thank you everyone for your patience and help. I hope my struggles will inform a more serious technical issue.
The issue has been solved. It was user error. I think I mistakenly formatted the extra harddrive as APFS before a long data transfer without checking first, which resulted in me giving up on searching for potential mistakes in my process.
I formatted an SSD drive to 'Mac OS Extended (Journaled)' using a borrowed MacOS Macbook and 'Disk Utility' app. I checked and it was able to mount on the Trisquel Mac with hfsplus and aforementioned tools installed. I transferred the files in increments to avoid errors. The information is now available on the SSD, but read-only, which I hope I can change.
