Dependecy Issue
I get this error when installing a package:
Dependency is not satisfiable: libboost-filesystem1.49.0 (>= 1.49.0-1)
In the Trisquel repos the latest version of libboost-filesystem1.48.0. Is there a preferred way to get the latest version if its not in the repos? I found 1.49.0 in the Debian repos but thought there might be a standard way to handle these issues in Triquesl.
thanks.
What package did you install (to have this dependency issue) and was it in the Trisquel repositories?
The package was grive and it was not in the Trisquel repositories.
Here is your problem. Mixing repositories can be problematic. Especially when you use repositories that are not for the version of the system you are using or of the system yours is based on (Ubuntu 12.04 if you use Trisquel 6.0, for instance).
