Desinformación acerca del software libre
Creo que el siguiente artículo puede dar a entender que el software libre es inseguro, pero las bases de datos de las que se habla no estaban protegidas con algo como una contraseña motivo por el que fueron atacadas (igual les pasa a bases de datos hechas con software privativo, pero de esas no hablan en ese artículo):
What?
Is an article in Spanish, where author told which free software is being affected by cyber attacks, but that article doesn’t tell reality, problem about databases in that article is which their owners didn’t protect it with passwords (this affect databases which uses privative software too, not only databases which uses free software –only these are mentioned in that article).
PS: if somebody considers which this topic have to be moved to Spanish forum, move it or delete.
Regards.
