Does Remastersys work with Trisquel?
I'm running Trisquel 5.0 and wanted to know if Remastersys works with it? I heard it was a good way to make a back-up of your entire set-up and then install it on another computer or just another hard drive in the event of a hard drive failure.
If it works, what version is good? If it does not work, is there something that works like it?
Thank you very much.
I've never worked with remastersys, but there's always Clonezilla.
+1
Yes, remastersys works fine on Trisquel.
+1
