error boot usb libreboot
Hey, guys, how you doing?
I have a t400 with the libreboot installed by someone else and am trying to oar a live ob, but I am having some difficulties.
some isos simply did not enter the system, another I recently downloaded from the parabola, from a message like: "error: syntax error
error: incorret command"
this iso gave normal boot on a notebook with bios and started.
Is there anything else I need to do on the libreboot home screen?
Sorry my English.
Thank you!
hello there
grub's isolinux/syslinux parser doesn't always work
Try the advice here:
https://libreboot.org/docs/gnulinux/grub_boot_installer.html#booting-isolinux-images-manual-method
Thank you leah! I will take a look yes.
if you keep getting stuck, come to IRC. #libreboot on irc.libera.chat
if i'm there i'll guide you, otherwise usually someone is there to help people
