Flashed Librecmc on WNDR3800
Do you get decent speeds with VPNs with on these routers? also can you set Librecmc to be run like a travel router.
Thanks
I use this routeur with libreCMC and openVPN to get a fixed public IPv4 to host services, the speed was about 15 Mbits/s when I tested while the VPN provider is claiming to support much higher speeds, so the issue might be with that routeur.
I have a spare one, so I'll try another VPN directly with my PC and with this routeur and report.
By the way, I recently ordered the new RYF-certified routeur from Thinkpenguin but have not received it yet.
I saw that they dropped that ! have you tried wireguard ? and which model are your running ?
Who is "they"?
My provider does not have wireguard.
and which model are your running?
Are there several models of WNDR3800?
I tested the same VPN with:
- Thinkpenguin new RYF routeur: DL 63 Mbps UL 88 Mbps
- openVPN on my desktop: DL 240 Mbps, UL 225 Mbps
