FreeTube for trisquel
7 risposte [Ultimo contenuto]
Cathie3
Iscritto: 04/22/2024
Dear community
I would like to install an adblocker on youtube or an app like Freetube.
If I understand well i should never install anything out of the internet (?) but is there an aquivalent in the repository? I didnt find anything...
Thank you very much in forward.
Cathie
prospero
Iscritto: 05/20/2022
There will be no add served if you use an invidious instance instead. You can search for videos using the invidious search field, or you can simply copy and paste the video reference.
For example, use https://inv.nadeko.net/watch?v=iZe0R5aVDoM instead of https://youtube.com/watch?v=iZe0R5aVDoM.
IBM1130
Iscritto: 09/24/2020
Ublock Origin is FOSS software available on Github. It is available in the Trisquel repository, but I had problems with the installer pulling obsolete versions.
https://github.com/gorhill/uBlock/blob/master/README.md
FYI, Ublock Origin-Lite sometimes works better than Ublock Origin on Abrowser for blocking Youtube ads.
https://github.com/uBlockOrigin/uBOL-home/blob/main/README.md
prospero
Using an invidious instance has the triple advantage of:
1. not being dependent on system updates to clean the mess after youtube broke your non-alphabet browser, all the work being done by the remote invidious instances;
2. not having to install anything out of repo;
3. enhancing privacy.
This is why I consider invidious as second best choice, second only to completely cutting off from google/alphabet/evil.
mangeur de nuage
Iscritto: 09/27/2015
Invidious is great but remember that a single server ca withstand so much, people need to host their own instances to grow the numbers of proxies.
mangeur de nuage
Reminder that the web firewall uBo has many blacklist you can also activate.
eric23
Iscritto: 06/30/2017
I have yt-dlp and mpv and watch videos straight from youtube with mpv. MPV will let you watch videos, but if you want to download one use yt-dlp.
Iscritto: 07/24/2010
Have you installed https://gnuzilla.gnu.org/extension.php?id=607454 (uBlock Origin) yet? It is probably the most famous ad blocker. However, like prospero, I use Invidious.
There is no DRM in Trisquel: you are free to install whatever you wish on your system. If you take software out of Trisquel's repository, you are on your own though! If you decide to do so, then, for your own sake, you should check if it is free software. Notice that it may even be malware.
Flathub is a popular third-party repository that allows to some extent to filter out proprietary software (but it will still include free software to launch proprietary software: Trisquel would not have those in its repository!). To install Flatpak and setup Flathub's "floss" subset, execute in a terminal:
$ sudo apt install flatpak
$ flatpak remote-add --subset=floss flathub https://flathub.org/repo/flathub.flatpakrepo
A free graphical interface to youtube-dl may please you: https://flathub.org/en/apps/search?q=youtube-dl
