Inviato da ngawang il Lun, 08/19/2013 - 18:47
Gnome Panel
How do I add/remove applets and short cuts from the Gnome panel? This is something that should be so obvious and simply but I've searched online and found nothing.
Lun, 08/19/2013 - 18:52
#1
Either Alt+Right click on the panel (if Metacity is your window manager) or Alt+Windows key+Right click on the panel (if Compiz is your window manager) will give you a contextual menu that includes an entry to add "elements" to the panel.
Lun, 08/19/2013 - 20:11
#2
Thank you very much.
