Graphics problems after upgrade to 5.5
After upgrading my laptop to Trisquel 5.5 I have experienced problems related to X and/or the graphics driver. These problems prevent me from using the graphical interface, so I've had to boot off of a 5.0 CD to post this.
It's a x86-64 laptop with a Radeon HD 6520G graphics card. It works in 5.0 but for some reason it can't be configured properly under 5.5.
Here's the output from running `startx` manually: http://ompldr.org/vZG4xMA/startx.txt and here's Xorg.0.log: http://ompldr.org/vZG4xMw/Xorg.0.log. The error in question appears to be:
(EE) Failed to load module "fglrx" (module does not exist, 0)
(II) [KMS] drm report modesetting isn't supported.
(EE) RADEON(0): Chipset: "SUMO" (ChipID = 0x9647) requires KMS
(EE) Screen(s) found, but none have a usable configuration.
It's my understanding that fglrx is the proprietary driver, but of course I'd rather not install that. I've looked for solutions but the recommendation just seems to be to use the proprietary driver. Running an `modprobe radeon` simply causes my screen to crash entirely. Is it possible to get this chipset working with the free radeon driver? My kernel is 3.3.3-gnu if that helps.
I have a radeon as well and I took a look at my logs and it says the same thing about missing fglrx which is the proprietary driver. Never used it. So this is likely unrelated.
Are you disabling KMS? Tried doing it? Besides that, if nothing else seems to work, perhaps you could try specifying a wrong chipid, see man radeon. I don't know if that could be dangerous though...
If you can't make radeon work, try specifying vesa, see man vesa. Could be that this was what you were actually using before.
Hope you get it sorted.
Manually creating xorg.conf and specifying the vesa driver solved my problem.
Thanks much.
Glad to hear and you're welcome.
Manually creating xorg.conf and specifying the vesa driver solved my problem. Thanks much.
