Inviato da calher il Mar, 04/30/2024 - 20:18
Guix package does not update
I installed the "guix" package in Trisquel and did a "guix pull" but it failed and said I found a bug. I will be submitting this to the bug-guix mailing list as well.
Mer, 05/01/2024 - 05:14
#1
You can also try to run guix pull again. I did it after failing some time ago - and it worked!
Mer, 05/01/2024 - 20:22
#2
I ended up doing
rm -rf /var/guix /gnu
and installing with the installation script.
