Having Problem updating and upgrading
I am sorry if i am posting in the rong forum page as oter i could understand the language as i am not from spain
have trouble updating and upgrading
captainfreeky@captainfreeky:~$ sudo apt-get -f upgrade
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following NEW packages will be installed:
gtk2-engines-pixbuf:i386 libgail-common:i386 libgail18:i386 libgtk2.0-0:i386 libsdl1.2debian:i386
The following packages have been kept back:
linux-image-generic trisquel-base trisquel-base-recommended
0 upgraded, 5 newly installed, 0 to remove and 3 not upgraded.
244 not fully installed or removed.
Need to get 0 B/5,071 kB of archives.
After this operation, 9,822 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
(Reading database ... 121430 files and directories currently installed.)
Unpacking libgtk2.0-0:i386 (from .../libgtk2.0-0_2.24.10-0ubuntu6+6.0trisquel2_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/libgtk2.0-0_2.24.10-0ubuntu6+6.0trisquel2_i386.deb (--unpack):
'./usr/share/doc/libgtk2.0-0/changelog.Debian' is different from the same file on the system
No apport report written because MaxReports is reached already
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Unpacking libsdl1.2debian:i386 (from .../libsdl1.2debian_1.2.14-6.4ubuntu3+6.0trisquel1_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/libsdl1.2debian_1.2.14-6.4ubuntu3+6.0trisquel1_i386.deb (--unpack):
'./usr/share/doc/libsdl1.2debian/changelog.Debian.gz' is different from the same file on the system
Unpacking gtk2-engines-pixbuf:i386 (from .../gtk2-engines-pixbuf_2.24.10-0ubuntu6+6.0trisquel2_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/gtk2-engines-pixbuf_2.24.10-0ubuntu6+6.0trisquel2_i386.deb (--unpack):
'./usr/share/doc/gtk2-engines-pixbuf/changelog.Debian' is different from the same file on the system
Unpacking libgail18:i386 (from .../libgail18_2.24.10-0ubuntu6+6.0trisquel2_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/libgail18_2.24.10-0ubuntu6+6.0trisquel2_i386.deb (--unpack):
'./usr/share/doc/libgail18/changelog.Debian' is different from the same file on the system
Unpacking libgail-common:i386 (from .../libgail-common_2.24.10-0ubuntu6+6.0trisquel2_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/libgail-common_2.24.10-0ubuntu6+6.0trisquel2_i386.deb (--unpack):
'./usr/share/doc/libgail-common/changelog.Debian' is different from the same file on the system
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
captainfreeky@captainfreeky:~$ sudo apt-get -f autoremove
The following extra packages will be installed:
The following packages will be REMOVED:
apt-clone archdetect-deb dpkg-repack gir1.2-json-1.0 gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 libdebian-installer4 libgtkmm-2.4-1c2a python-pyicu sbsigntool
0 upgraded, 5 newly installed, 10 to remove and 3 not upgraded.
After this operation, 3,280 kB of additional disk space will be used.
Sorry I am still new and in learing phase of linux can say biggner
I tied this command and this below
sudo dpkg --configure -a
gtk2-engines-murrine:i386
ibus-gtk:i386
libcanberra-gtk-module:i386
ia32-libs-multiarch:i386
libsdl-net1.2:i386
libsdl-image1.2:i386
gtk2-engines:i386
ia32-libs
teamviewer
librsvg2-common:i386
libsdl-mixer1.2:i386
libcanberra-gtk0:i386
libsdl-ttf2.0-0:i386
>teamviewer
Proprietary software gives you nothing but trouble.
can't i install it though ?
if not then how can i remove the teamviewer with the command
Sure you can. It's the source of this whole mess. I don't know how to uninstall it.
You can uninstall it easily via "Synaptic". Just open Synaptic and move on to:
Status > Installed (local or obselete)
find teamviewer right-click on it and choose "Mark for complete removal" and finally press Apply.
and what if i want to install team viewer and make it working ?
though it is not in synaptic to install team viewer
You won't find any proprietary package in trisquel repositories, because it's a 100% free-libre distro.
And this forum won't give you any help on how to install non-free software.
