How do I revert back to the default interface?
2 risposte [Ultimo contenuto]
Pandya
Iscritto: 11/11/2014
Namaskar! I've just installed Flidas and while playing with different type of interface on MATE Tweak, I changed to Ubuntu MATE. Now how can I revert back to the default one? since I'm not finding appropriate option from drop-down menu.
AllegatoDimensione
tweak.png60.22 KB
calher
Iscritto: 06/19/2015
Do
mate-panel --reset --layout trisquel
Layouts are stored in /usr/share/mate-panel/layouts/.
I had to run the command twice to get the panel back up.
Found this tip at
https://ubuntu-mate.community/t/how-to-tweak-your-panel-layouts/884
Pandya
Thanks! It has worked!
Though I tried resetting gsettings key which didn't work:
gsettings reset org.mate.panel default-layout
