Inviato da GrevenGull il Dom, 05/20/2018 - 12:56
How to downgrade from Replicant 6 to Replicant 4.2
Anybody?
I am stuck.
After I installed Replicant 6 my device won't boot into download mode or recovery mode.
And there seems to be no "downgrading" options inside the OS :/
Gio, 05/24/2018 - 17:51
#1
Problem solved?
Btw, what exact device do you have?
Gio, 05/24/2018 - 18:13
#2
No the phone is still in the same situation as described above :/
I have posted this in the Replicant forum as well, I'll check back here if someone has any ideas, but there's good chances I have "bricked" it.
Galaxy S2
