Inviato da grave_123 il Mer, 07/04/2012 - 00:31
How to have two monitors have different backgrounds?
Is there a way where I can have two monitors have different backgrounds in Trisquel?
Mer, 07/04/2012 - 04:19
#1
Install nitrogen. It works.
Search "nitrogen" in Synaptic or via Terminal.
sudo apt-get install nitrogenthen you open it with Alt+F2 or Terminal:
nitrogenand add the images directories in "preferences".
