How to install Rockbox on Sansa e250R ?
I need help to install rockbox on my sansa e250R (v. 1.0.2.165) i try to follow this instructions > https://www.youtube.com/watch?v=r4VxqRwQS70 but doesn't work for my device. The rockbox's intrucctions site special instructions seems kind hard to follow > http://www.rockbox.org/wiki/SansaE200R nvm i'll try but seems doesn't work either.
Anyone have this same version of the sansa e250R (Rhapsody)? if so, how you installed rockbox on yours?
For help with Rockbox, perhaps using the Rockbox support resources is the best way? If you access http://www.rockbox.org/ you should notice on the left they have: Forums, Mailing lists, and IRC.
Recently I rockboxed my iPod 5g (just bought it some week ago only for rockbox and beacause you can replace memory and battery very very easily). I used auto-install, very very easy and foolproof. Yes, in GNU+Linux.
I know that rockbox is pretty simple to install yes but my problem is that my model RHAPSODY need to Modify the existing Sansa bootloader to disable the extra security features present only in the R series players. What a pain.
>> http://www.rockbox.org/wiki/SansaE200RInstallation
PD: Send me to the hole.
