how to verify trisquel 7 iso using gpg
Hi,
Please can someone explain this?
I have
the
.iso
.iso.asc and
.iso.md5
If I do
gpg --verify trisquel_7.0_amd64.iso.asc trisquel_7.0_amd64.iso.md5 I get BAD SIGNATURE.
Please can you help?
Thnaks you.
The signature file and md5sum file are both for the disc image. The signature isn't for the md5sum. Also, you don't need to tell GnuPG what file it's for; it figures that out from the filename.
But I suspect your actual problem is that you don't have a copy of Ruben's public key. You'll need to obtain a copy of that and import it to your keyring with gpg --import.
Try removing the .md5 from the second file in your command, I believe the signature is for the iso, not the .md5 file.
