HP Mini 210-1020ez Wi-Fi
15 risposte [Ultimo contenuto]
egon
Iscritto: 11/07/2025
First of all, hello everyone! (This is my first post here.)
I recently acquired an old HP Mini 210-1020ez netbook, which I'm trying to bring back to life. After installing Trisquel Mini 11.0.1 LTS Aramo on it, everything seems to work just fine, except the Wi-Fi card. Just to make sure the card wasn't damaged or anything else, I used a non-free distro to check: the card works, so I guessed it would have been related to the abscence of non-free drivers/firmwares.
The card in question is a Broadcom 4312, which then I further identified using:
lspci -nn -d 14e4:
Which outputs:
02:00.0 Network controller [0280]: Broadcom Inc. and subsidiaries BCM4312 802.11b/g LP-PHY [14e4:4315] (rev01)
Looking online I found out that the card should be supported by the b43 drivers: https://wireless.docs.kernel.org/en/latest/en/users/drivers/b43.html.
I also found out about the OpenFWWF project (http://netweb.ing.unibs.it/openfwwf/), where free firmwares for the BCM43XX cards have been developed. Shouldn't these in association with b43 make the card work?
In case this should not work, I could be able to swap the card with a Realtek 6317A-RTL8188EE 802.11b/g/n, which is supposed to run without problems: https://h-node.org/wifi/view/en/1637/Realtek-Semiconductor-Co---Ltd--RTL8188EE-Wireless-Network-Adapter.
In that case my question here is: would the card be compatible with the antennas already present in the netbook? Could it be possible to replace the previous one without the BIOS blocking it?
Many thanks in advance for your time.
IBM1130
Iscritto: 09/24/2020
Hi Egon-
This may be of help or not. This card was tested on Trisquel 7.0 and didn't work. But we are now at 11.0.
https://www.h-node.org/wifi/catalogue/en/1/1/undef/undef/undef/undef/wifi-works/undef?search_string=4312&submit=Search
Model: Broadcom Corporation BCM4312 802.11b/g LP-PHY (rev 01)
Does it work with free software?
no
The good news is the this card is now working on Linux Mint as of July 2025- https://forums.linuxmint.com/viewtopic.php?t=449587
Note; They filed a bug report on this:
https://bugs.launchpad.net/ubuntu/+source/b43-fwcutter/+bug/2116888
Good luck!
egon
Hello IBM1130!
Yes, the H-Node was the starting point of my research on the matter.
About the other two links you you posted: aren't the broadcom-sta-dkms, firmware-b43-installer, b43-fwcutter, broadcom-wl & b43-firmware packets made by - or depending on Broadcom and then non-free pieces of software? Or am I wrong?
If possible, I would like to stick to free/libre software to solve this issue.
Anyway, thanks for replying!
Avron
Iscritto: 08/18/2020
Whether the BIOS would block the replacement of the wifi card or not is usually not indicated in any manual, so perhaps the only way to know is to try.
I found a manual of that laptop, it says that the WLAN antenna is with 2 connectors. If you want to try replacing the wifi card with another one, if the connectors fit and only 2 antennas are needed, I see no reason why there could be a problem. The manual I found says some models have instead an Atheros 9285 wifi card. Such a card is listed on H-node as working with free software. If the BIOS is blocking some cards, there is chance that it is not blocking that one, but not sure.
egon
Ok, thanks! I'll keep that in mind in case no free driver/firmware is found and the replacement card I already got around won't be allowed by the BIOS.
IBM1130
Iscritto: 07/24/2010
BCM4312 is not listed as a "known supported board" in the description of the openfwwf package, which is installed by default in Trisquel 11.
I believe RTL8188EE should work as reported on h-node thanks to the work put in early 2018 into GNU Linux-libre 4.16-gnu: https://www.fsfla.org/pipermail/linux-libre/2018-April/003284.html
egon
@IBM1130:
Thanks for the suggestion, but this solution highly exceed my budget for this project. I also would prefer not to have any external dongle on the device.
@Magic Banana:
I see. I will try to install the RTL8188EE as soon as possible and I'll update you on the matter. Thank you!
You are welcome (on this forum too, by the way!). As you wrote, DRM may prevent you from using the Wi-Fi board with the RTL8188EE chipset. Try and see.
eliotime3000
Iscritto: 06/05/2016
In the case of the Realtek RTL8188CE, it seems that the support for that WiFi card became fully supported by the linux-libre kernel. I tested on Trisquel 10 and 2020 version of Parabola GNU/Linux-libre and it works flawlessly.
egon
@eliotime3000: I see. The problem is that the BIOS is locked and it prevents any OS from booting if a non-officially listed Wi-Fi card is detected when turning the device on. At this point the Atheros 9285 seems to be the only PCI-E card compatible both with the kernel and the BIOS's whitelist. In the meantime I ordered a cheap one and I'll keep you updated (see last message).
egon
I just connected the RTL8188EE card. When powering up the computer, I'm greeted by the following error:
104-Unsupported wireless network device detected.
System Halted. Remove device and restart.
This probably just means that the card is not on the BIOS whitelist.
I am now considering whether I should use a free BIOS (not sure if available for my machine), modify the existing one, or just try to find a Atheros 9285 somewhere.
Avron
Here is the manual page that indicates the spare parts references for wifi cards: https://mans.io/files/viewer/204140/55
I don't know whether the BIOS accepts any of those, or only the exact same one like you have. If you want to try, https://www.mcac.com/605560-001.html says it is the original model of the Atheros card with the exact spare part number from the manual. Their price is really high, but the photo might be useful to check a cheaper offer from ebay. For example, https://www.ebay.com/itm/166766777204
I doubt you can find free BIOS for this machine.
egon
As of now, I ended up buying a cheap version of it listed as "Atheros 9285 AR5B95 AR9285 802.11B/G/N 150 Mbps PCI-E". We'll see...
eliotime3000
My best recommendation is to search the specific version that has been manufactured for HP products (being the belonging spare part number and/or designed for another HP laptop) to avoid issues with the propietary HP BIOS.
egon
Atheros 9285 arrived, but it produces the same error message.
In the end I solved the problem installing the card in second mini PCI-E slot, rather than in the main one. Apparently the second slot is not being checked by the BIOS during the boot up process.
