I accidently removed the battery indicator from my task bar
How can I bring it back?
I'm using Trisquel 7 by the way
Hello muhammed!
Perhaps try right clicking on the task bar.
Click "Add to Panel", then click "Indicator Applet" or "Indicator Applet Complete".
Thanks wpurcell; it worked!
I now find myself in a slightly ridiculous situation ... totally my own fault:
In the "Add to Panel" program, I saw something called "Indicator Applet Complete". I was pretty sure that I didn't need it ... but I was curious. So I clicked on it.
I now have:
a) three wifi buttons
b) two battery indicators
c) three volume selectors
d) a power button (that I don't think I had before --and don't need), and
e) three digital clocks.
I have no idea how to get rid of these extras ...
To remove these, hover your cursor over the offending applet, hold down the super (windows) button and the alt button, then right click.
You should have two options: Move or Remove from panel.
Give that a try.
