i am going to challenge myself for 3 days
i am going a free for three days - i install trisquel and going to see if i found both my community and distro or just the comunity :) my only ? is how can i install Mate?
Congratulations! Good luck with Trisquel.
I believe you can install mate from the Ubuntu PPA for Trusty. If you're using
Trisquel 7 (which I assume you are) the commands are as follows:
$ sudo add-apt-repository ppa:ubuntu-mate-dev/ppa
$ sudo add-apt-repository ppa:ubuntu-mate-dev/trusty-mate
$ sudo apt-get update
$ sudo apt-get install mate-desktop-environment
Good luck! More info here: https://trisquel.info/en/wiki/installing-mate
so far so good!my real test is tomrrow with installing my three most use apps - one out two been instalk
Cool! and do you have any GNU/Linux games to play with? like NeverPutt and Tux Racer
right now i more concern with this ugly ubuntu logo on my menu then games.. using mate and loving it
ok day 1 is done and day 2 is coming up- im really thinking this confirms it - i need to make a choice of really determine if i want bells and whistles or some thing simple like this.
best distro around.
Exactly, best in terms of ease of use and the freedoms are brilliant.
now to my laptop - installing antergos right now and i can sleep....
