Icecat language is not set into system language
Hi,
Icecat language is not set into system language, after installation.
I know there is a way to install another languages to Icecat, downloading its extension from a node of https://www.gnu.org/software/gnuzilla/ .
Cannot it be installed automatically from Trisquel?
Thanks.
Have you yet performed "sudo apt-get update" and "sudo apt-get upgrade" ?
These two steps together usually cause Trisquel to download and install almost all available language support to a fresh installation of Trisquel unless one takes extra steps to avoid that result.
Alternatively, open Synaptic Package Manager, then type "language" into the search bar, then select "Search Results" and scroll down through the umpteen choices of language packs, selecting as few or as many that you do/do not want to be installed.
In my case, the task was to unselect all but my language of choice for a USB-Stick installation; your task my differ.
Afterwards, select "Apply" and Synaptic Package Manager will take it from there.
Here is the lnguage packs folder -> ftp://ftp.gnu.org/gnu/gnuzilla/38.7.1/langpacks/
I guess you want it in Spanish. Download ->
ftp://ftp.gnu.org/gnu/gnuzilla/38.7.1/langpacks/icecat-38.7.1.es-ES.langpack.xpi
and then just drag it to Icecat.
Is there any reason not to install the language pack ("icecat-locale-*") from the package manager?
Supertramp said: Here is the lnguage packs folder -> ftp://ftp.gnu.org/gnu/gnuzilla/38.7.1/langpacks/
I would like to get lnguage packs folder in..... the..... martian language.
What is Inguage?
Is that a developers new language?
I could speak and write geringosa, you want to learn?
Doesn't "Language Support" (in the "System Settings") propose you the installation of the language pack?
I did:
apt-get update
apt-get upgrade
apt-get dist-upgrade
Still Icecat without system language.
When I go to language support into system settings, it says that language is not completely installed and suggests to install:
libreoffice-help-en-gb
libreoffice-l10n-en-gb
libreoffice-l10n-en-za
mythes-en-au
hunspell-en-ca
Why language is not completely installed before? (When I installed Trisquel, I choose my region language. And I have updated.)
Are you going to fix it?
Not having "Language Support" proposing IceCat's localization looks like a bug to report: https://trisquel.info/en/project/issues
As for the incomplete localization, I am not sure it is bug. Those packages probably are not on the ISO to save space.
Complete localization,
Could it be done with a command?
Why apt-get update, upgrade, etc... don't work?
Thanks.
