Install Huawei E392 USB LTE Drivers
Hi all,
I've got a Huawei E392 USB LTE modem that works fine under kali linux but when I stick it in my trisquel it does nothing.
What should I do to get this working?
Doing a lsusb -v brings this related info:
Bus 003 Device 003: ID 12d1:1505 Huawei Technologies Co., Ltd. E398 LTE/UMTS/GSM Modem/Networkcard
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x12d1 Huawei Technologies Co., Ltd.
idProduct 0x1505 E398 LTE/UMTS/GSM Modem/Networkcard
bcdDevice 0.00
iManufacturer 3 Huawei Technologies
iProduct 2 HUAWEI Mobile
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 1 Huawei Configuration
bmAttributes 0xc0
Self Powered
MaxPower 500mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk-Only
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
Device Status: 0x0000
(Bus Powered)
Thank you for your time and efford :-)
Greetins,
Fred.
Hello!
The probably cause is it requires a proprietary firmware to run that is included in Linux but not in Linux-libre.
If that is the case, your best bet is to get another modem.
How can I make this one run? I really can't aford another modem...
You probably need to do usb mode switching.
Huawei modems usually start in storage mode and need to be instructed to change the mode to use device as a modem.
Thank you BugRep ;-)
So for all out there that need to get it working on trisquel (in my case a Huwaei E392 LTE Usb Modem (from TMN Portuguese provider)) here's how:
type in terminal as root (or sudo the commands):
lsusb -v | less
Get the vendor and product ID from the result of the above command.
Like: Bus 003 Device 003: ID 12d1:1505 Huawei Technologies Co., Ltd. E398 LTE/UMTS/GSM Modem/Networkcard
Note the two references after ID (12d1 and 1505)
Now append this line in /etc/modules:
usbserial vendor=0x12d1 product=0x1505
(to edit type "nano /etc/modules" as root, add the lines, hit ctrl+o to write the file (save) and ctrl+x to close nano.)
Reboot your computer and your done.
Set up a new mobile broadband connection and your online! ;-)
Greetings 2 all.
