Installing midori from ppa
Hello
The version of Midori(lightweight browser) in trisquel repos is 0.2.4, while the newest version available is 0.3.2. I tried to install from the midori ppa, but it seems that the version from ppa crashes with the old version.
dpkg: Feil ved behandling av(norwegian for "Error when dealing with") /var/cache/apt/archives/midori_0.3.3-0.1~mmwkt1_amd64.deb (--unpack):
trying to overwrite '/etc/xdg/midori/config', which is also in package trisquel-desktop-common-data 4.5-2
How fix this?
Daniel
Yup, I second this. I also was unable to install the latest Midori via PPA.
I managed to install Midori from this PPA on Trisquel 4.0:
https://launchpad.net/~midori/+archive/ppa
(Note that the Webkit PPA https://launchpad.net/~webkit-team/+archive/ppa is required.)
I also received an error but solved it by doing
$ cd /var/cache/apt/archives
$ sudo dpkg -i --force-overwrite midori_0.3.6-1~llwkt1_amd64.deb
Of course you need to replace the package with the one that appears in the error log.
