installing tq 11 when disconnect usb iso stick?
2 risposte [Ultimo contenuto]
tonlee
Iscritto: 09/08/2014
Do you remove the usb iso installation stick
when the message installation complete displays? Or
else when? Thanks.
Iscritto: 07/24/2010
You need to reboot in the installed system. While the live system is shutting off, a message will tell you to unplug the USB stick, if I remember well.
Lugodunos (non verificato)
Lugodunos
I had no message telling me to remove the USB stick, so I shut it down and removed it, the, I started the computer and it worked.
