Is my kernel still being low latency if updating it?
Hi, I updated my kernel to the latest version, and I wanted to know if it was still low latency like the pre-installed ones.
# dpkg -l | grep linux-image
rc linux-image-3.13.0-39-lowlatency 3.13.0-39.66+7.0trisquel2 amd64 Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii linux-image-3.13.0-74-lowlatency 3.13.0-74.118+7.0trisquel2 amd64 Linux-libre kernel image for version 3.13.0
ii linux-image-4.4.0-gnu 4.4-gnu-1.0 amd64 Linux kernel, version 4.4.0-gnu
ii linux-image-lowlatency 3.13.0.74.80+7.0trisquel2 amd64 lowlatency Linux-libre kernel image
Yes, you are. Read the description of "linux-image-lowlatency":
This package will always depend on the latest lowlatency kernel image available.
There's also linux-image-4.4.0-gnu installed, not only "linux-image-xxx-lowlatency" kernels.
You are right. I do not know how I could ignore it. It must be the kernel from http://linux-libre.fsfla.org/pub/linux-libre/freesh/
And it probably is the one that runs by default (unless GRUB_DEFAULT in /etc/default/grub was changed) because it is the latest one. The following command would tell:
$ uname -r
If you do not want this kernel, simply remove it; for instance using the "Synaptic package manager" in the "System settings". And the related repository can be removed from /etc/apt/sources.list too (here using Trisquel's default text editor):
$ gksu gedit /etc/apt/sources.list
bit x86 SMP
command would tell:
$ uname -r
OK, thanks. And by the way, what for is it separated from the kernel?
"linux-image-lowlatency" is a "meta-package": it does not install anything by itself and only exists to impose dependencies. In this case: the latest lowlatency kernel image available. Currently, it is linux-image-3.13.0-76-lowlatency. It was linux-image-3.13.0-74-lowlatency a few days ago. But both versions still are in the repository and can be installed in parallel.
In fact, when a new version is automatically proposed to you (thanks to the meta-package whose dependency is modified), installing the new kernel image does not replace the older version. In this way, if something goes wrong with the new kernel, you can still boot the older one. It also means you must remove by hand (using for instance the "Synaptic package manager" in the "System settings") the oldest kernels from time to time. Otherwise you end up filling up your root partition (or your /boot partition if it is separated from /) with kernels: just keep he latest one and the one before that if you haven' had any problem with it.
available.
