Need help getting drivers.
4 risposte [Ultimo contenuto]
anonymous
So I bought the first wifi adapter in this list: https://www.pandawireless.com/Drivers%20|%20Panda%20Wireless.html. Anyway I thought it would work with linux libre because I think the source is available, I think this because you have to compile the driver. I could be wrong. When I insert the device into my laptop it shows up but says "device not ready, firmware needed". I went through the instructions to get the driver but I keep getting errors when trying to compile it. I'm not sure if someone knows but does this device have any chance of working, or anyway to install firmware.
jxself
Iscritto: 09/13/2010
Which of these devices do you have?
http://www.pandawireless.com/Products%20|%20Panda%20Wireless.html
Tree_brock (non verificato)
PAU03
jxself
After reviewing the source code, it appears that it relies on proprietary software to operate. I recommend a different one that doesn't:
https://www.thinkpenguin.com/gnu-linux/penguin-wireless-n-usb-adapter-gnu-linux-tpe-n150usb
OK, I'm going to purchase that one, plus I get a 5% discount because I'm a FSF member.
