[Need help] Stuck at upgrade mid
2 risposte [Ultimo contenuto]
kesavan
Iscritto: 12/16/2013
Trying to upgrade from 10 Nabia to 11 Aramo. Everything seems good but upgrade took too long time. Then I realized the upgrade actually got stuck in mid:(Refer the screenshot)
Progress bar shows:
Configuring libmbedcrypto7 (amd64)
Terminal inside shows:
Setting up fonts-noto-unhinted (202012225-1build1) ...
Meanwhile I'm able to open other applications(eg: Abrowser).
Upgrade got stuck for last couple of hours and I'm unsure to reboot the device.
Any help is much appreciated.
AllegatoDimensione
Screenshot at 2024-03-12 20-15-03.png28.39 KB
kesavan
Accidently the upgrade window got closed. Executing "sudo apt update && sudo apt full-upgrade" from terminal made the upgrade complete success!
andyprough
Iscritto: 02/12/2015
Excellent! I've noticed that apt seems more resilient for me recently. I also had an update get stuck and then closed a few weeks ago and then "sudo apt update && sudo apt full-upgrade" fixed it. If I recall correctly, some years ago that would create an error where I would have to go in and clean the apt cache and do different steps to get it working again.
