[OT] Fetching BBC Radio Programs with get-iplayer?
I wish to fetch an episode of a radio drama that was broadcast on Radio 4 last night, according to the schedule. Last week, I gave the command,
get-player "Good Omens" --future
and got numbers that, I believe, correspond to the 6 episodes in the series. Today, I tried
get-iplayer --get 12130
this is supposed to be the first episode.
Program came back 'no matches'. Now, any searches for "Good Omens" come back 'no matches'. Did BBC pull the program, or, am I doing something wrong?
Thanks,
-Dave
Dave, it's the 'app' iPlayer interface get_iplayer uses not the web one. So Radio 4 stuff seems to appear sometime after last live repeat. If you want it before then use the iPlayer web URL for the episode with youtube-dl. You'll need to recode with avconv out of libav-tools for many a audio player though.
[edit]
Equally old stuff which is on the web disappears from the app version early.
The command you need for Ep #1 is
youtube-dl http://www.bbc.co.uk/programmes/b04knthd
Good job done by leny2010. I also want to learn this by searching on google. I have already tried to do this but fail. May be i am doing something wrong. I like a program of Radio and commonly i used BBC News Online (http://bbcnewsplanet.com/) to listen the radio program. Thanks for sharing the nice information with us.
I found the schedule for the radio program of interest and downloaded the episodes with youtube-dl instead of get-iplayer. Why do they use flash video for files containing only audio? I tried converting one to ogg with oggconvert; the result sounded horrible; I'll just keep the flv's for now.
The BBC has changed the way it works and so get_iplayer no longer works as it used to. (The BBC - making stuff with public money and then making it hard to get).
The only method that now works (as far as I know) is to get the program to load in the browser and then copy the program ID from the address bar.
Example command: get_iplayer --pid=b04wzt43 --type=radio
This will pull down the program with the PID b04wzt43.
Point being that get_iplayer cannot get a list of stuff that's available anymore. This was true when I last used get_iplayer which was sometime in November/October last year.
Hope that helps.
