Is "packages.trisquel.info" is down/dead?
Recently I observed (for two days) that I can't open http://packages.trisquel.info/ also checked from external sites (to see that http://packages.trisquel.info/ is not down for me or really down) which also results that http://packages.trisquel.info/ is down/dead.
Then Why http://packages.trisquel.info/ is not active? When it will be available again?
What to do about searching Trisquel Package Database?!
You can use e.g.
apt-cache search QUERY
for searching the descriptions of packages and
apt-cache search -n QUERY
for searching package names.
The results depend on your sources.
The development server is being migrated to a new machine, service will be restored soon.
Personally, I've been pretty much off the air since 12/25, however, at that time the 'backend' of the new build system was undergoing tests. That is the part which delivers signed binaries of Trisquelized packages to the repo. There is also a bug against packages.trisquel.info for it not knowing which packages Trisquel is delivering (rather than other upstream flavours of the same package). Final development / fixing either or both of these could result in a p.t.i outage. The clue that this might be the case is as you can see by absence [1] Aklis, the Trisquel BOFH, has been working on some non-GitLab task for four days. Either that or he's sleeping off the accumulated sleep debt from December's sprint, but that seems unlikely.
http://packages.trisquel.info/ is now working fine.
[Solved]
