Possible to get libpython3.6 for anki?
The folks who maintain Anki (https://apps.ankiweb.net/), the flash card program, just announced that on 1/1/2020, version 2.0 will no long be able to synchronize with their cloud, which is too bad. I use this program/app on several devices and update my cards daily.
I downloaded version 2.1 and did make install and that went okay, but when I run anki from the command line I get this message:
[32228] Error loading Python lib '/usr/bin/libpython3.6m.so.1.0': dlopen: /usr/bin/libpython3.6m.so.1.0: cannot open shared object file: No such file or directory
It looks like the most recenlibpython in the repo is 3.5.
Could someone please share way to fix this?
I don't normally insist on the latest versions of things, but this is pretty important. I wish I could just wait until March 28, 2362 (https://trisquel.info/en/forum/when-will-trisquel-90-release#comment-144814) to do a complete upgrade.
Thanks in advance!
NAIB
Well, good news: The battery died so I did an unintentional reboot and it works now. So I can wait patiently for 2362 after all.
