Possible Memory Leak?
In Trisquel 7 when I use sudo I get this message:
no talloc stackframe at ../source3/param/loadparm.c:4864, leaking memory
Is anyone else seeing this?
Same for me.
The bug report has been already submitted in Issues.
SirGrant has assigned the bug to upstream for a patch; I conclude it is solved in Ubuntu 14.10 (Utopic) and the patch will soon be available for Trisquel 7.0
If you look at the upstream bug which will fix this it's scheduled
for inclusion in 14.04.2 which is due February 2015. The Trisquel
Issue is marked Upstream pending that.
Same problem before I ended up rolling back to 6.
Not for this bug I hope. There's a range of bypasses in the upstream bug report and as the original reporter there has said in the past few days - he's been running with this bug all this time and not had any problems from it.
