python3-distupgrade conflicts with trisquel metapackage
Tried to file a bug report against Belenos, thou it won't let me submit it. FYI this metapackage includes system's GUI updater.
Up.
How are you trying to install it? Did you install anything to replace it's function?
I have it installed on my system (I am running Trisquel 7.0 on this machine).Here are a few commands for reference:
root@trisq:~# apt-cache showpkg python3-distupgrade
Package: python3-distupgrade
Versions:
1:0.220.6+7.0trisquel11 (/var/lib/apt/lists/es.archive.trisquel.info_trisquel_dists_belenos-updates_main_binary-amd64_Packages) (/var/lib/dpkg/status)
Description Language:
File: /var/lib/apt/lists/es.archive.trisquel.info_trisquel_dists_belenos_main_binary-amd64_Packages
MD5: f6e22affea82016bac7bf2c9371af261
Description Language: en
File: /var/lib/apt/lists/es.archive.trisquel.info_trisquel_dists_belenos_main_i18n_Translation-en
1:0.220.5+7.0trisquel10 (/var/lib/apt/lists/es.archive.trisquel.info_trisquel_dists_belenos_main_binary-amd64_Packages)
Reverse Depends:
trisquel-release-upgrader-gtk,python3-distupgrade 1:0.220.6+7.0trisquel11
trisquel-release-upgrader-core,python3-distupgrade 1:0.220.6+7.0trisquel11
trisquel-release-upgrader-gtk,python3-distupgrade 1:0.220.5+7.0trisquel10
trisquel-release-upgrader-core,python3-distupgrade 1:0.220.5+7.0trisquel10
python3-update-manager,python3-distupgrade
auto-upgrade-tester,python3-distupgrade
Dependencies:
1:0.220.6+7.0trisquel11 - python3:any (2 3.3.2-2~) python3-update-manager (2 1:0.196.2~) python3-apt (2 0.8.5~) lsb-release (0 (null)) python3-update-manager (3 1:0.165) python3-update-manager:i386 (3 1:0.165) python3-update-manager (3 1:0.165) python3-update-manager:i386 (3 1:0.165)
1:0.220.5+7.0trisquel10 - python3:any (2 3.3.2-2~) python3-update-manager (2 1:0.196.2~) python3-apt (2 0.8.5~) lsb-release (0 (null)) python3-update-manager (3 1:0.165) python3-update-manager:i386 (3 1:0.165) python3-update-manager (3 1:0.165) python3-update-manager:i386 (3 1:0.165)
Provides:
Reverse Provides:
root@trisq:~# apt-cache depends python3-distupgrade
python3-distupgrade
Depends:
python3:i386
python3
Depends: python3-update-manager
Depends: python3-apt
Depends: lsb-release
Breaks: python3-update-manager
Breaks:
Replaces: python3-update-manager
Replaces:
root@trisq:~# apt-cache rdepends python3-distupgrade
python3-distupgrade
Reverse Depends:
auto-upgrade-tester
Edit: Formatting was very wakward. Probably better to zoom-out to make sense of it all.
FYI, little dependency hell.
