Scanners for Trisquel Out of Box
Wondering if anyone can suggest newer model Document Feed scanners that will work on Trisquel out of the Box???
I believe http://www.openprinting.org/printers is also a good place to look at for scanner support as well as printers.
Hi, I know that HP Officejet 4500 G510a works very well indeed. You have
to start the scan in the computer software (GNOME Simple Scan, for
example can do this), because if you try to do so from the printer's
scan button, it'll say that there's no place to send scan to.
I'll make an entry on H-Node about it for further reference.
