Screen does not work on Live mode Acer aspire 1360
Dear all,
I have tried installing trisquel mini and plain trisquel on an acer Aspire 1360[1,2] laptop. Sorry I was not able to give a list of hardware of the is laptop.
The problem can be seen on the image that I have hopefully attached.
I get the ISOlinux live CD loader to work fine and I can see the menu of "try trisquel" "mem test" "load from first hard drive" just fine. The problem is when i do choose load trisquel and the the screen goes wierd.
I have been able to access the comand line using the ctl+alt+F2 (or was it alt F2?) but anyway I normally would use xrandr but that does not work because in the comandline mode X is not loaded.
I tried a couple of other comands on the net but they do not fit the problem at hand.
[1] http://support.acer-euro.com/drivers/notebook/as_1360.html
[2] http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire1360/Aspire1360mv.shtml
| 20130115_001.jpg | 510.4 KB |
Oh! I also tried other non free distribuitons such as ubuntu and lubuntu. Same problem. The only one that seemed to work was crunchbang linux. But of course I want trisquel.
I want to say update the kernel and that will probably fix your problem:
----- Mensaje original -----
> https://trisquel.info/en/wiki/update-linux-libre-kernel
thanks chris. But it requires a reboot at the end. since i am running a livecd does this mean that i should install trisquel on the command line and then follow the wiki? (I would have to use nano and not gedit).
