Starting the LibreVR Livestream soon
I recently set up libnginx-mod-rtmp on my Trisquel bases VPS. My plan is to regularly broadcast my progress on LibreVR on weekends.
The Website on https://stream.isengaara.de is currently empty and shows "403 Forbidden". I will fill the site later, and also make a page for my games that I am currently working on.
The first stream will start today at 14:00 Berlin time, I will be talking about both future plans and what is currently possible on the Valve Index connected to the Talos II.
I have also begun working on a libre hardware design for a Lighthouse tracking device using the iCE40 FPGA and the TS4231, with "Respects Your Freedom Certification" in mind.
To view the stream use one of those commands:
vlc https://stream.isengaara.de/hls/librevr.m3u8
vlc https://stream.isengaara.de/dash/librevr.mpd
Recordings are ready -> uploaded to my machine running Trisquel:
https://stream.isengaara.de/2024/LibreVR1.mkv
https://stream.isengaara.de/2024/LibreVR2.mkv
https://stream.isengaara.de/2024/SaberTest.mkv
Again once OBS crashed on my Talos II, so I had to split my stream into two halves. I did the SaberTest before and found out that there is a bug in libsurve atm. I am going to fix that soon.
