System crashed?
Hello
my OS (Trisquel) seems to habe crashed. I am still comng to tge homescreen. However, there i cant do anything and it doesnt react to mouse clicks.
Should i reinstall trisquel?
Wäre do i find prepated Installation Sticks with trisquel?
Which Software do you recommand for remote maintenance?
Thank you very mich in forward
Cathie
There are some typing errors in my Text.Sorry. Hope it is still clear
Can you go to a tty if you press Ctrl-Alt-F2? Just trying to see if your keyboard is working. If your keyboard is working and not your mouse, you could just have a mouse problem.
Hello Andyprough, thank you very much for your answer. I have tried this now but it still doesn t work. So probably i have to reinstall the system? The tip is valuable to me for future similar problems and so thanks again. gratefully greetings!
Hello again you are great!!! I now realized that i can write, then used an external mouse and it works! Thank you so much!
Do you think it is a Hardware problem vor can it also be triggered by Software issues?
So n
If you are trying to use the touchpad, look at Preferences->Hardware->Mouse, then touchpad tab, and check that "activate touchpad" is checked (my system language is not English, so I am guessing the names of the English menus, but perhaps it is not exactly those names).
In my experience, it is checked be default, but perhaps it could be unchecked for some reason.
This is for libreboot, but it works for canoeboot and also other bioses probably too:
https://libreboot.org/docs/linux/grub_boot_installer.html
Follow the below if you don't want to visit site.
The # lines are just instructions
#If you downloaded your ISO while on an existing Linux system, here is how to create the bootable Linux USB drive:
#Connect the USB drive. Check lsblk, to confirm its device name (e.g., /dev/sdX):
lsblk
#For this example, let’s assume that our drive’s name is sdb. Make sure that it’s not mounted:
sudo umount /dev/sdb
#Overwrite the drive, writing your distro ISO to it with dd. For example, if we are installing Foobarbaz Linux, and it’s located in our Downloads folder, this is the command we would run:
sudo dd if=~/Downloads/foobarbaz.iso of=/dev/sdb bs=8M; sync
This is how I do it.
