Trisquel 8 with kernel 4.15.0-99 BusyBox error
Hello,
I'm using Trisquel 8 and I installed the linux-image-4.15.0-99-generic kernel from the Trisquel repositories, but after the reboot I got a BusyBox error. See the attached image.
Some suggestion how to fix that?
Thank you
| IMG_20200501_200904_1.jpg | 197.71 KB |
Can you boot the previous kernels? GRUB should still list it in its "Advanced options for Trisquel" (or something like that).
You can chroot from a live session. Boot from a live CD and open a terminal. Then, assuming your root partition is /dev/sda1
$ sudo su
# TARGET=/media/sda1
# mkdir -p $TARGET
# mount /dev/sda1 $TARGET
# mount --bind /dev $TARGET/dev
# mount --bind /dev/pts $TARGET/dev/pts
# mount --bind /proc $TARGET/proc
# mount --bind /sys $TARGET/sys
# cp /etc/resolv.conf $TARGET/etc/
# chroot $TARGET /bin/bash
This places you in a root terminal on the trisquel system. Do whatever you want to do there,e.g., uninstall that kernel.
To exit from chroot:
# control-D
This brings you back to where you were in the live session and you can unmount
# umount -l $TARGET/dev/pts
# umount -l $TARGET/proc
# umount -l $TARGET/sys
Hello,
thank you, I managed it. Unfortunately I didn't install all the needed kernel packets, this is why I got this error message.
Now the OS is booting fine, but after the login the system is frozen at 90% of my efforts.
Any advice how to fix this error?
I do not understand what that means. Anyway, reading (with journalctl) the logs right before the freeze may help to diagnose the problem.
