Trisquel Sugar 9: installation problem
Hello I am trying to install Trisquel Sugar 9 in dual boot
with Sparky Linux on a netbook eeepc 10001px.
If I run the installer, after duringbthe connection to my home wifi
appear a popup window tellme the installer have a unknown problem and
the Sugar gui start to try ti detecte wich is the problem (how?)
I need to install Trisquel Sugar because we need to use the italian language
and the live iso have only english and spanish.
Maybe is better to format the ssd and dual boot with Trisquel 9 (or Mini 9)?
Sorry for my bad english
I need to install Trisquel Sugar because we need to use the italian language and the live iso have only english and spanish.
No, you need not. You can install the default MATE edition of Trisquel. Its installer, that you can launch by double-clicking on the related icon on the live desktop, first asks what language it should use. Italian is an option. The installed system will be in Italian. Some missing translations will however be missing. A few clicks in the "Region & Language" utility (that name will be in Italian) will install them.
What if I want my friend's children to be able to use Trisquel Sugar 9 in Italian?
Am I also compelled by your executive order to use Trisquel MATE instead?
If paolo really wants Sugar, then the Sugar ISO is obviously the right choice. Nevertheless, it does not look like it is the case. He writes: "I need to install Trisquel Sugar because we need to use the italian language".
Also, I forgot to write: to have the installed system in Italian, the live system must have an Internet connection. Plugging an Ethernet cable will work. If the Wi-Fi chipset is supported, choosing the proper network after clicking on the related icon will work too.
Thanks for your answers @Magic Banana and @lanun, I resolve installing Trisquel Mini9 and from the packages manager I installed the 2 packages trisquel-sugar wich installs all the Sugar software. Now I have in dual boot Mini 9 and Sugar.
Later I check the iso as you suggest.
Merci Magic Banana you are very kindly
