Inviato da just-empty il Mer, 12/19/2018 - 08:21
usb 3.0
my laptop freeze after i eject usb 3.0 hdd
is it only me or there is solution for this
Mer, 12/19/2018 - 12:28
#1
No such problem on the (all Trisquel 8) systems I administrate. You can always try to update the kernel, following the instructions on https://jxself.org/linux-libre/
Mer, 12/19/2018 - 13:36
#2
thanks for the respon
