Wine not installable.
I know I've installed it on Trisquel before. Here's what I get:
sudo apt-get install wine
[sudo] password for ewl:
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
wine : Depends: wine1.4 but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
It's because it depends on ia32-libs, which is broken. See this bug report, there's a fix toward the bottom:
Thanks for your quick response. That did it!
