wireless problem
Hello everybody,
I have a lenovo g50-30 with trisquel 7 and I am trying to connect to wifi with this wireless adapter from thinkpenguin https://www.thinkpenguin.com/gnu-linux/penguin-wireless-n-usb-adapter-w-external-antenna-gnu-linux-tpe-n150usbl
After some searching I found that a module called ideapad_laptop was blocking the wifi so I removed it. Now the adapter blinks for a moment and then it is down again. Do you have any ideas?
Thank you.
You should write to name at domain (CEO of ThinkPenguin and a Trisquel user).
